Project log-21102023
A project log for New open source hardware 1U satellite project.
tranvinhquangTRAN.VINH.QUANG 10/26/2023 at 15:390 Comments
I AM DESIGNING TO VISUALIZE THE FINAL 32 NODES VERSION.
 I CHOSE THE BGA CHIP TO BE THE MAIN MONITORING CHIP AND THE NODES ARE DESIGNED TO BE LOCATED ON THE EDGE OF THE CIRCUIT BOARD.
THIS WAY HELPS ME EASY TO CHECK AND CONNECT WITH OTHER PARTS.
TO INCREASE STABILITY, I HAD TO DESIGN AN ADDITIONAL PROTECTIVE SHIELD FOR THE CIRCUIT. ON BOTH SIDES.
IT IS A SHIELD MADE BY CNC MACHINE, SO I DESIGNED THE NECESSARY PARAMETERS FOR PROCESSING THIS SHIELD.
