idea for a flying bagpipe
Vito wrote 05/29/2015 at 16:08 1 point
This is the idea, for a RC flying toy:
A single propeller, or a small centrifugal compressor blows air into a reservoir which is the body of the flying machine. The reservoir can even be made of textile material. So it will be an inflatable body.
In strategic points of the body there are nozzles equipped with small piezo valves (example http://vikingat.com). The air jets coming out from those nozzles keep the thing flying and control the position.
The piezo valves are really low power and can be opened and closed very fast (tens of hz), allowing to control the flow and the thrust in a PWM fashion, reducing pressure loss.
The prop or the compressor only has to keep the pressure of the body constant.
Only one motor = less current consumption, inflatable body = lightweight.
By the way I have no experience with flying things... Everything should be properly sized for low pressure drops across nozzles and reservoir, and also its size should be a tradeoff between capacity and aerodynamic drag. Could it work? What do you think?
