2SC945: Pinout, Equivalents, and Datasheet
ericksonbrecken1998ericksonbrecken1998 wrote 04/02/2022 at 02:08 • 3 min read • Like
2SC945 Description
The 2SC945 is a high-frequency OSC NPN audio frequency amplifier transistor. It is an old Japanese bipolar audio NPN transistor, which has been widely used in high-frequency circuits for pre-amplification in amplifier applications.
无
2SC945 Features
  1.  Power dissipation of 0.4Watts.
  2.  Collector current of 0.15A.
  3.  Collector-base Voltage: 60 volts
  4.  Operating and storage junction temperature range: -55°C to +150°C • Epoxy has a flammability grade of UL 94 V-0
  5.  Level 1 Moisture Sensitivity
2SC945 Pinout
无
无
2SC945 CAD Model
Symbol
无
Footprint
无
3D Model
无
Specifications
Package:TO-226-3, TO-92-3 (TO-226AA) (Formed Leads)
Operating Temperature: -55°C~150°C TJ
Pin Count: 3
Packaging: Tape & Box (TB)
Transistor Type: NPN
Transition Frequency: 150MHz
Number of Terminations: 3
2SC945 Equivalents
2SC2856TRANSISTORSMPSA56/D26Z{OPTION18}TRANSISTORSKSC2310-OTRANSISTORSBC368-16TRANSISTORSBSS38TRANSISTORSZTX455QTRANSISTORSJC557ATRANSISTORSBC546BRL1TRANSISTORSZTX450TRANSISTORSBC546B-AMMOTRANSISTORS
Applications
1. Switches with low current
2. Pre-amplifiers
3. Low-power motor H-bridge circuits
4. Circuits for audio frequency amplifiers
5. Oscillator circuits
Where To Use 2SC945
Because it has a low base voltage of 5V, it can be easily controlled by an MCU/MPU if used as a switch. It can switch loads of up to 50 volts. With its complementary A733 PNP transistor, it can also be used as an oscillator.
Package
无
Manufacturer
Founded in 1991, Micro Commercial Components Corp. (MCC) is a manufacturer of high-quality discrete semiconductors to the consumer markets. It provides diodes, rectifiers, transistors, MOSFETs, voltage regulators and protection devices.
Datasheet
https://pdf.easybom.com/r/datasheets/microcommercialco-2sc945grap-datasheets-7531.pdf
Check out more details on: https://www.easybom.com/blog/a/the-introduction-of-2sc945
Like
