LT9611UXC Lontium Description
The LT9611UXC is a multimedia converter chip manufactured by Lontium Semiconductor Corporation. It is designed to convert MIPI DSI (Display Serial Interface) and CSI (Camera Serial Interface) signals to HDMI 2.0 output. This makes it a valuable component for connecting MIPI-based displays or cameras to HDMI displays or monitors, especially in applications requiring high-resolution video and data transfer.
LT9611UXC Specifications
Single/Dual-Port MIPI DSI/CSI Receiver:
- Compliant with D-PHY 1.2, DSI 1.3, and CSI-2 1.3 standards.
- Integrated DSC 1.2 decoder.
- Configurable as 1 or 2 ports.
- Supports 1 clock lane and 1, 2, 3, or 4 configurable data lanes per port.
- Data lane speeds ranging from 80 Mbps to 2 Gbps per lane.
- Skew calibration for optimal signal integrity.
- Programmable receiver equalizer.
- Supports data lane swap (arbitrarily) and polarity inversion (independent).
- 3D support: can receive L and R frames or alternate odd-L/even-R pixels.
- Supports DSI in both burst and non-burst modes.
- DSI supports various video formats with or without DSC/CSC.
Digital Audio Input:
- I2S interface supporting 2-channel audio with various sample rates (32-192 kHz) and sample sizes (16-24 bits).
- SPDIF interface supporting PCM, Dolby Digital, and DTS digital audio at up to 192 kHz frame rate.
- IEC60958 or IEC61937 compatible.
HDMI 2.0 Transmitter:
- Compliant with HDMI 2.0b, HDMI 1.4, and DVI 1.0 standards.
- Compliant with HDCP 2.2 and HDCP 1.4.
- Supports a high data rate of up to 6 Gbps.
- On-die back termination.
- Programmable transmitter swing and pre-emphasis.
- AC-couple capable.
- Supports channel swap (arbitrarily) and polarity inversion (independent).
- Capable of supporting 4K resolution at 60Hz.
- Supports 3D formats (side-by-side/full).
- Supports various video formats with or without DSC/CSC.
- HDR (High Dynamic Range) support.
- TMDS scrambling for EMI/RFI reduction.
- Supports SCDC (Status and Control Data Channel).
- 5V tolerance for DDC (Display Data Channel) and HPD (Hot Plug Detect) I/Os.
Miscellaneous:
- CSC (Color Space Conversion): Supports RGB <-> YUV444 <-> YUV422 conversion.
- Integrated CEC (Consumer Electronics Control) controller.
- External oscillator.
- Integrated microprocessor.
- Embedded SPI flash for firmware and HDCP keys.
- GPIOs for system controls.
- Integrated 100/400 kHz I2C slave interface.
- Firmware update capability through SPI or I2C interface.
- Power supply: 3.3V for I/O and 1.2V for the core.
- ESD (Electrostatic Discharge) protection: 4kV HBM (Human Body Model).
- Wide temperature range: -40°C to +85°C.
- Package: QFN64 (7.5mm x 7.5mm).
- Read more: LT9611UXC Lontium: Datasheet, Features and Applications
- Send inquiry: https://www.avaq.com/bom
