Hey readers! How is it going? I hope you are happy after getting a Cricut machine. This range of machines is excellent and creates a good impact on your crafting skills. Hence, if you want to hone your DIY projects, Cricut is something unbeatable. To get started, you need to set it up on your device, such as a computer or phone. And, today I’ll teach you how to connect Cricut to phone through this blog.
Being a full time DIYer and a blogger, I always hear from my users that they are always a little confused about their machine’s setup. Hopefully, I’ll be able to help them all. If you’ have been struggling with the connection process, here you’ll get all the clarity. So, let’s get started!
What Is a Cricut Design Space App?
If you’re expecting a Cricut machine to connect to your phone, you know that it can’t be possible without an application. Hence, Cricut offers its design app known as Cricut Design Space app to create designs that you convert into your favorite crafts. So, to get it on your phone, you need to install its application on your phone. I’ll mention all the steps.
How to Download Cricut Design Space on Phone?
Before we proceed to learn how to connect Cricut to phone, here is something more important. As you know Cricut Design Space is crucial to setup a Cricut machine on a phone, you need to download and install it on your phone. Look at the steps below to learn them quickly.
For Android
All Android users can follow these steps to get the Cricut Design app on their Android phones.
- Go to the Play Store on your Android device and open it.
- Now, locate the Cricut Design Space in the search bar.
- When you see the icon for the Cricut app as a green C letter, select it.
- After that, hit the Install button to install that app.
- Next, you’ll see your app on the home screen along with other apps.
- Now, click on the icon of Cricut Design Space.
- In the last step, begin the sign-in and design.
Finally, you have the Cricut software on your Android device. Let’s check the steps for iOS.
For iOS
If you are an iOS user, don’t worry. The steps are simple for it, too. Let’s check the steps here.
- First of all, open the App Store on the iOS device’s home screen.
- Now, navigate to the Cricut Design Space app in the search bar.
- After that, you’ll see a Get button; click on it to download your app.
- Next, when your app is downloaded, open it and select one option: Sign In or Cricut New Machine Setup.
Now, the Cricut Design app is on your iOS device. Here, the door for creativity is just a step away from you. Connect your machine to your phone to finalize the Cricut setup on the phone.
How to Connect Cricut to Phone?
Finally, you are here to learn the connection procedure between your Cricut and phone. So, let’s learn how to connect Cricut to phone wirelessly.
For Android
Are you an Android user? You can easily connect your Cricut to your phone using the following steps. Here, I’m using the Bluetooth connection. Let’s see the final steps in detail.
- In the beginning, turn on your machine and check whether it is 10-15 feet away from your phone or not.
- Then, head to the phone Settings.
- After that, head to the Bluetooth option.
- Next, enable the Bluetooth option if it’s not.
- Thereafter, select your Bluetooth module name from the list.
- If you need to enter the four-digit PIN, enter “0000”.
- Finally, you’re ready with your Cricut machine connected to an Android device.
That’s how to connect Cricut to phone. Now, you have the freedom to utilize your Cricut machine the way you want.
For iOS (iPhone or iPad)
Well, if you’re an iOS user, here are the steps for you. Below, I’m mentioning some step-by-step instructions for connecting a machine to an iOS. Let’s see how to connect Cricut to phone Bluetooth.
- In the beginning, ensure that the distance between your Cricut and phone is not exceeding 10-15 feet.
- On your phone’s screen, open the Settings option.
- After that, enable the Bluetooth option and search for your Cricut machine.
- Next, once you see your machine in the list, select it and continue to pair it.
- Now, you may need to enter the four-digit PIN and enter “0000”.
- At last, click on the Pair option to end the process.
That’s how to connect Cricut to phone. These steps are common for iPhones and iPad. Once you connect your Cricut to your phone, various possibilities are available to you now.
Conclusion
I have tried my best to make you understand about the connection process between a Cricut machine and a phone. Here, you can create anything with your Cricut machine. Once the setup is complete, you’re allowed to use Cricut Design Space Software the way you want. If you want premium features, you can opt for the Cricut Access subscription. This subscription will make your work easy by offering you with so many advanced features. Now, connect Cricut to your phone and enjoy your day!
For more information visit: www.cricut.com/setup login
Source: How to Connect Cricut to Phone
