Specifications
  • Base price: 990 EUR for full KIT (available from Fabrikor)
PRINTING SPECIFICATIONS
  • Build volume (mm): 300 X 300 X 300
  • Auto levelling: Optional
  • Minimal layer height (mm): 0.05
  • Steps/mm (X & Y): 80
  • HotEnd: 1 X E3D-V6 1.75 mm (swappable with any E3D)
  • Travel speed (mm/s): 200
  • Print speed (mm/s): 150
  • Heated bed: Yes - 24V or 230V
MECHANICAL SPECIFICATIONS
  • Desktop size (mm): 460 X 440 X 660
  • Frame: Plywood
  • Linear rails: 8 mm ground hardened steel
ELECTRICAL SPECIFICATIONS
  • Supply Voltage (V AC): 240 or 110
  • Supply connection: Switched and fused IEC Socket. Lead not provided.
  • Power supply: 1 X 24V 100W / 1 X 24V 350W (if 24V bed)
  • Electronics control board: RUMBA + LCD
  • Motor drivers: 4 X DRV8825 (X,Y,Z,E)
  • Motors: X: 46 Ncm 1.8° / Y: 46 Ncm 1.8° / Z: 46 Ncm 1.8°
SOFTWARE SPECIFICATIONS
  • Recommended slicing software: CURA / Slic3r
BUILD TIME
  • From full-kit: 12h
