Very primitive voltage indicator by Attiny13
A project log for Minimalist A-go-go
A project inside Attiny. I will not step out for larger one till I complete it.
kodera2tkodera2t 04/03/2016 at 07:110 Comments
I am still in wonderful Attiny world, where I have learned lots of fundamentals of computer itself. This time I made a very simple and primitive voltage indicator by LEDs utilising A/D converter of ATtiny13.
As it is, ATtiny is 8-pin MCU and VCC, GND and RST ( I am still beginner, and cannot hand it away) total 3-pins are already occupied. So I used the rest 5 pins as, PB3 (pin 2) for A/D input and LEDs are driven by 4-pins by PB0, 1, 2, and 4. I am enjoying assembly language, since I can see and understand very fundamentals and the code is written by AVR assembly as follows.
; webADCattiny13.asm
; Created: 4/1/2016 12:52:26 PM
; Author : kodera2t
.def r_temp1 = R16
.def r_temp2 = R17
.def r_temp3 = R18
.equ lv_1 = 0x2b ; values for voltage comparison
.equ lv_2 = 0x56
.equ lv_3 = 0x81
.equ lv_4 = 0xac
.equ lv_5 = 0xd7
setup:
ldi r_temp1, ((1<<ADEN)+(1<<ADSC)+(1<<ADATE)+(1<<ADIE)+(0<<ADIF)+(1<<ADPS2)+(1<<ADPS1)+(1<<ADPS2))
out ADCSRA,r_temp1 ;starting A/D conversion
                     ;(free running mode)
;ldi r_temp1, ((0<<REFS0)+(0<<ADLAR)+(1<<MUX1)+(1<<MUX0))
;Vcc as analogue reference (currently commented out)
ldi r_temp1, ((1<<REFS0)+(0<<ADLAR)+(1<<MUX1)+(1<<MUX0))
;internal 1.1V as analogue reference
out ADMUX,r_temp1 ; setting PB3 for A/D input
ldi r_temp1, (1<<DDB4)+(0<<DDB3)+(1<<DDB2)+(1<<DDB1)+(1<<DDB0)
out DDRB, r_temp1
; PB0, 1, 2, 4 for LED output (PB3 for input)
main: ; main loop start!
in r_temp1,ADCL ;reading lower bit of A/D result
in r_temp2,ADCH ;this program uses lower 8 bits only, therefore the comparing results will be periodical for input voltage variation
cpi r_temp1, lv_1 ;comparing measured result with lv_1=0x2b
brlo s_vchk_1 ; if the measured value is lower than 0x2b, jump to s_vchk_10
cpi r_temp1, lv_2 ;comparing measured result with lv_1=0x56
brlo s_vchk_2
cpi r_temp1, lv_3 ;comparing measured result with lv_1=0x81
brlo s_vchk_3
cpi r_temp1, lv_4 ;comparing measured result with lv_1=0xac
brlo s_vchk_4
cpi r_temp1, lv_5 ;comparing measured result with lv_1=0xd7
brlo s_vchk_5
rjmp main ; closing main loop
s_vchk_1:
ldi r_temp3, 0b10111 ;all LED are off (negative logic)
out PORTB, r_temp3
ret ; return to main loop
s_vchk_2:
ldi r_temp3, 0b10110 ;PB0 is on
out PORTB, r_temp3
s_vchk_3:
ldi r_temp3, 0b10100 ; PB0, 1 are on
out PORTB, r_temp3
s_vchk_4:
ldi r_temp3, 0b10000 ; PB0, 1, 2 are on
out PORTB, r_temp3
s_vchk_5:
ldi r_temp3, 0b00000; all LED are on
out PORTB, r_temp3
The generated hex file occupies 231 bytes in flash. We still have enough huge room in ATtiny13 !!!!! Actual operation can be found in the following movie... have fun!
