Ordering Parts Soon - Suggestions?
A project log for sdramThingZero - 133MS/s 32-bit Logic Analyzer
Add an old SDRAM DIMM to your SBC for a 133MS/s 32-bit Logic Analyzer, add ADCs for a Scope...
eric-hertzEric Hertz 10/24/2016 at 18:180 Comments
Update1: Buy some flip-pins! See below, they're perty-slick.
Update2: Removing '543, note added...
Update3: Polyimide "Labels" added at the bottom.
As has been the plan all-along, I'm trying to keep the necessary-parts down to stuff most digital-logic-users either have in their collections, or should...
Here I'm branching out a tiny bit... in the interest of speed and functionality. The odds of your having *the fastest* 74xx245 in your collection are pretty low. But, of course, this system is *now* running at 30MHz on a solderless-breadboard with some HC (and an AHC) parts, and there's no reason you couldn't try to push the limits of whatever 74-series parts you happen to have around.
So far the order contains:
I also ordered a couple ATMEGA8515's, again... I didn't really want to invest in such a "lowly" AVR, with so many more-functional ones out there these days... but I've a few projects using these, and as I recall I've only one that hasn't at least one fried GPIO. Those guys are great for prototyping (using one for sdramThingZero, as we speak), but probably good to have a couple *decent* ones around... And, they're only $2.88, whereas the pin-compatible '162 was over double that, and the '644-'2564s are nearly triple. I'm broke. Two for the cost of 2/3rds of one.
So, that's the order, so far... any suggestions as to other similar parts I haven't considered?
DIMM Sockets! Woot, they're cheap, too! But only 451 left in stock after my order, so I ain't linking 'em for yah ;p
This is kinda a boring order... I feel the need for something fun, blinky, or moving...
Update: The pins used in Philip's project #OSHChip V1.0 are now available for purchase for our own projects! This might be just the "fun" thing I need in this order-cycle.
Certainly more fun than damaging my solderless-bread-boards with regular ol' square header-pins. And, can be inserted into a DIP socket, when I've soldered up a board.
I've invested in some for my breakout-boards, and projects down the line.
Polyimide/Kapton-Tape...
This sh*t ain't cheap.
I managed to come across some "labels" which are allegedly used for barcodes, etc. on PCBs. Not ideal, but cheaper than a roll of kapton-tape. $3.21 for 25 1in x 1/4in labels. This'll be an interesting approach, they're supposedly thermal-printed, yet I'll most-likely be using 'em ala elm-chan's usage under that NEC chip, and elsewhere:
Rated for 260deg C, which is 500deg F, which seems a bit low... I usually use 600deg F on my iron, unless I'm soldering something *really big*, in which case I bump that dial up to 11. Still, $3 to give it a try, vs $50?! for a roll of kapton-tape... and if you don't pay attention to the tape's thermal-characteristics, (which I never did, before), might just well be rated for 500F... worth a try.
Still holding off on "the big order", though, until I've had some time to make sure I haven't forgotten anything... Ideas?
