Build - Step 5
A project log for 18 DOF High-Flotation Hexapod Robot
Six legs, 18 servos, with optional high-flotation mode. My first project that combined robotics and 3D printing.
kendoken.do 09/03/2017 at 00:390 Comments
5. Attach mid leg piece to hip joint
Insert the fat end of one of the deeper nubs into the bottom of the mid leg piece. Repeat the procedure for attaching the hip joint to the main body, but using the mid leg piece instead of the main body. Don't forget to seat the horn on the servo and attach to both the servo and the hip joint. (I didn't attach to hip joint because I ran out of screws!)
