Slackware gets hard-float... but needs newer RPi...
A project log for CM3 Board + Backend-Library + Bee Hive Monitor
An open solution enabling everone to build and maintain a IoT enabled sensor network. BeeStalker is the reference for you project!
johannwilhelmjohann.wilhelm 08/25/2016 at 16:120 Comments
For a long time there were no updates here... in the meanwhile BeeStaker was field-tested and found ok for now...
Well, to be honest a lot of fine-tuning needs to be done.
First of all, I need to upgrade my RPi A+ boards to at least RPi 2 models due to Slackware ARM now got a hard-float distribution.
As now summer's going to end, this project will come alive soon.
73
