The new hardware seems to work...
A project log for CM3 Board + Backend-Library + Bee Hive Monitor
An open solution enabling everone to build and maintain a IoT enabled sensor network. BeeStalker is the reference for you project!
johannwilhelmjohann.wilhelm 02/24/2017 at 01:390 Comments
... but still a lot to test...
Some minor bugs are in the power-board design... but nothing really bad :)
btw 5V@2A were no problem... I need a new load for full 5V@5A... and some more batteries... only have 4 identical ones so far :)
So far the charger works and the protection circuits for the batteries seem to work fine...
73
