Portal gun screenshots
Top display visible here.
Handle to body arc visible here.
Turning the invisible dial..
And.. the almost never seen input method, the actual input dial on the back.
And... what a projected portal should look like.
So my three pictures should probably be...
White spots and spatter around the edges with a couple arcs.
Yellow border, with arcs in a spiral to the center.
And a green center with some negative arcs so the image shifts.
That will look sooooo cool :-)
Scary green lights, now UR gettin' somewhere :)
