This log starts with the so called circumplex model of affect. Re-drawn and simplified model:
You might notice, that this model implicates the use of the KNN algorithm immediately. More formally: let the sample space be a 2-dimensional Euclidean space IR², the center coordinates (0,0) and the radius r ∈ IR > 0, then our classes are located at:
and
A remark about Pleasure and Activation before we continue: Activation could be seen as a kind of entropy of the robot in a physical sense, depending for instance on the ambient light level and temperature. Pleasure could be seen as a success rate of a given task the robot has to fulfill or to learn.
The distance between two points in a 2-dimensional Euclidean space is given by
which follows directly from the Pythagorean theorem.
With the defined boundaries we get a maximum distance between a class point and a new sample point of:
Here is a little sketch I wrote to demonstrate how the emotional agent works:
const float r = 5.0; void setup() { Serial.begin(9600); Emotional_agent(5, 0); } void loop() { } void Emotional_agent(float x_P, float y_A) { if(x_P < - r) x_P = - r; // limit the range of x_P and y_A else if(x_P > r) x_P = r; if(y_A < - r) y_A = - r; else if(y_A > r) y_A = r; float emotion_coordinates[2][9] = { {0.0, 0.0, r, - r, 0.0, r/sqrt(2.0), - r/sqrt(2.0), r/sqrt(2.0), - r/sqrt(2.0)}, // x-coordinate of training samples {0.0, r, 0.0, 0.0, -r, r/sqrt(2.0), r/sqrt(2.0), - r/sqrt(2.0), -r/sqrt(2.0)} // y- coordinate of training samples }; char *emotions[] = {"neutral", "vigilant", "happy", "sad", "bored", "excited", "angry", "relaxed", "depressed"}; byte i_emotion; byte closestEmotion; float MaxDiff; float MinDiff = sqrt(2.0) * r + r; //set MinDiff initially to maximum distance that can occure for (i_emotion = 0; i_emotion < 9; i_emotion ++) { // compute Euclidean distances float Euclidian_distance = sqrt(pow((emotion_coordinates[0][i_emotion] - x_P),2.0) + pow((emotion_coordinates[1][i_emotion] - y_A),2.0)); MaxDiff = Euclidian_distance; // find minimum distance if (MaxDiff < MinDiff) { MinDiff = MaxDiff; closestEmotion = i_emotion; } } Serial.println(emotions[closestEmotion]); Serial.println(""); }
As far as I know the famous emotional robot 'Kismet' used a similar matrix. The robot can only express emotions mentioned in the matrix, using the KNN algorithm to find the closed match. I once wrote a little simulation where I used brightness and sound to manipulate the emotions of a virtual robot, see https://www.youtube.com/watch?v=e37p30Sybg8
I am excited about this emotion matrix. I hope you will write more details later on, how a robot can express for example an emotion of (0.5r,0.5r).
What do you think to make the default/basic emotion somewhere around (0.7r,0.3r)? I prefer a robot which is most likely to be happy than neural. :)
