Wiring and Other Tid-Bits
A project log for Combo CNC/3D Printer Build
Rebuild of 3D printer to be bigger and better than before
alex-andersonAlex Anderson 07/25/2016 at 21:450 Comments
Progress on the assembly front! The frame is back together and the wiring is almost complete. I have had to rewire a large portion to allow for the Gshield and Printrboard to used the same motor inputs. They are both tied into the same terminal block now and all I have to do is turn on either one so they will have motor access! The machine is back together and moving, I will most some of the first cut videos soon.
