Just Because I Build Ugly, Doesn't Mean You Should, Too
A project log for Beehive Monitoring, Now With WiFi
Using a WeMos ESP8266 D1 Mini and DHT22 Shield to monitor beehive temperature and humidity
don-r-crenshawDon R-Crenshaw 08/30/2016 at 22:110 Comments
For those interested, here's a Fritzing approximating my build. It doesn't show all the back-of-the-board solder connections or the twin rows of headers for mounting the breakout board. It also shows 5x2pin screw terminal blocks for the DHT22s instead of the 3x3pin terminal blocks I really used.
The voltage divider upper right is wired in series on the underside of the board as is just about everything wired in parallel.
Here's a schematic showing how simple it really is. My Fritzing-fu is weak but I think it's readable.
The code is the more interesting part of this but that's for a different log entry.
