Instructional on how to make a water-wise strawberry container
A project log for Urban gardening on the cheap
Using recycled materials to grow food effectively, and at very low cost.
richard-whitakerRichard Whitaker 04/29/2016 at 02:430 Comments
A water-wise strawberry container.
STEP ONE Punch or drill drainage holes in the base of a 5 litre container
STEP TWO
Bore a 28 mm irrigation hole at the top and a 28 mm hole in the centre of the planting station.
Drill a starter hole (for a jig saw) on the edge of a 100 mm D circle around the planting station.
STEP THREE
Cut out the planting station and cut a "keyhole" into the disc.
STEP FOUR
Punch a 3 mm irrigation hole in the cap of a soda bottle. Punch it from the inside.
STEP FIVE
Cut off the base of the soda bottle, push the neck through the irrigation hole and screw on the cap from the inside.
STEP SIX
Add a layer of gravel to cover the drainage holes, add potting soil, pre-irrigate, plant the strawberry and slide in the moisture shield.
