Sorting the bubbles
A project log for CPU7
A concept for a small RPN processor with interesting features
knvdKn/vD 03/28/2016 at 19:560 Comments
Although natively working with 16-bit words (14-bit pairs of instructions or data), CPU7 is also supposed to handle "raw" unformatted data in 8-bit, 16-bit, or 32-bit format. As an example that could be a hardware register, video memory, or anything which is not part of CPU7.
As a small coding exercise to test the flavour of the CPU7 assembler, here is the well known "bubble sort" of an area of unformatted bytes.
'! usage: addr len bubblesort8
:bubblesort8
  dup 1 > if          `! check if the array is more than one element
    enter
    1 over +          `! calculate end=addr+len; stack: beg, end
    1 swap dup        `! stack: end, beg, addr
    repeat
      dup rd8         `! stack: end, beg, addr, [addr]
      1 over ++ rd8   `! stack: end, beg, addr, [addr], [addr+1]
      < if            `! stack: end, beg, addr
        ++            `! addr=addr+1
      else
        2 over wr8    `! stack: end, beg, addr, [addr]
        1 over ++ wr8 `! stack: end, beg, addr
        drop dup      `! addr=beg; stack: end, beg, addr
      endif
    dup 3 over < until
    leave             `! clean up the data stack
  endif
  drop drop           `! remove the input parameters from the data stack
