First Program Runs Smoothly
A project log for muCPU: an 8-bit MCU
An 8-bit load-store CPU with 2 pipeline stages, designed in Logisim and implemented in VHDL + assembler written in Python
reed-fosterReed Foster 04/16/2016 at 20:013 Comments
Using the assembler I wrote in Python, I generated some hex code to store in the synthesized ROM on the FPGA. I also added a clock divider to slow the system clock from 50MHz down to 25Hz. This results in about a half second period between increments of the output vector.
Assembler Code:
lw r4, 176(r0) //value to count to should be stored at this address
lw r3, 177(r0) //increment value should be stored at this address
sub r2, r4, r1
bez r2, 8
sw r1, 252(r0)
bez r0, -8
add r1, r1, r3
sll r0, r0, r0
bez r0, -2
Hex Code:
0 => x"84b0",
1 => x"83b1",
2 => x"2142",
3 => x"5008",
4 => x"c1fc",
5 => x"40f8",
6 => x"0b21",
7 => x"0000",
8 => x"40fe"
Yann Guidon / YGDES wrote 04/17/2016 at 03:30 point
Congratulations !
Reed Foster wrote 04/17/2016 at 04:46 point
Thanks. That was probably the most excited I've ever been to see blinking leds :-)
Yann Guidon / YGDES wrote 04/17/2016 at 04:47 point
I understand ! been there too ;-)
