power consumption analysis
A project log for Green powered sailboat
The goal is to build a tiny autonomous sailboat able to travel potentially forever, powered using solar panels and wind.
silvio-biasiolsilvio biasiol 12/01/2016 at 16:440 Comments
This is a table with the main power consumption that I will have. I'm planning to use a camera and image recognition, in addition to the sonar, to build a simple but effective obstacle avoidance system.
component
power mW
utilization % (estimation)
Arduino UNO/micro
5v * 25mA/50mA = 125mW/250mW if active)
5v * 4mA = 20mW (sleep mode and hardware modifications)
80-90%
HRXL‑MaxSonar (ultrasonic rangefinder)
3.3v * 3.1mA = 10.23mW
40%
IMU (inertial measurement unit) * 2
3.3v * 145-350µA = 0.725mW/1.75mW each
100%
GPS unit
3.3V * 30mA = 99mW (average)
3.3V * 12mA = 39.6mW (for the antenna)
10%
DYMOND D 47 Servo (for the rudder)
5V * 250mA = 1250mW
50%
SW5513-4MA Sailwinch Servo (for the sail)
5V * 110-350mA = 550mW/1750mW
So the total power consumption should be around:
1750mW + 1250mW * ½ + (39.6mW + 99mW) * 1/10 + 1.75mW * 2 + 10.23mW * ¼ + 250mW * 4/5 ≅ 2594.91mW ≅ 2.595W
An eolic vertical turbine with an efficency of 35% (a round down estimate from average efficency), diameter of 10cm, height of 50cm and a wind speed of 7m/s c.a. (based on the average wind speed in Italy) should produce c.a. 3.230W (source: http://www.windstuff.org/calc/calc.php)
If, in addition, I use 4 solar panels 85x115mm of 18V and 100mA I should get:
18V * (100mA * 4) ≅ 7.200mW = 7.2W and supposing an efficency of 40% (day/night, circuit losess, water, dust, etc..) I should get c.a. 2.88W
These are just estimations of course! Please feel free to correct me if I've said something wrong :)
