The relays are here too !
A project log for SPDT16: 16-bits arithmetic unit with relays
Let's imagine I could get about 200 SPDT relays. Of course I would know what to do with them :-D But will 200 be enough ?
yann-guidon-ygdesYann Guidon / YGDES 05/01/2016 at 08:596 Comments
I now received some relays. It's time to characterize them !
Coil resistance : 35Ω
Coil inductance : 28000µH
Latching : 2V@0.06A (120mW ±20%?)
Release : 1.1V@0.04A (44mW ±20%?)
They are sold as 2.8V and I tested them with no load, I don't know how much current they can withstand. Anyway, switching 16 relays will draw 1A.
The coils look very compatible with the tiny incandescent lamps !
Vladimir wrote 04/11/2017 at 06:54 point
if u have measured coil res as low as 38 Ohm, then u got PC4.591.005 or PC4.591.12  good luck!
Vladimir wrote 04/11/2017 at 06:50 point
Hi. They are 0.2A DC max. Made for commutation 50 to 400 Hz. thats description, but in Russian http://lib.chipdip.ru/248/doc000248413.pdf
Yann Guidon / YGDES wrote 04/16/2018 at 01:58 point
Thanks !
Andrew Starr wrote 05/04/2016 at 08:55 point
Those are some cute relays :) What is their 'normal' application?
Yann Guidon / YGDES wrote 05/04/2016 at 09:01 point
surviving the Soviet era has been one of its successes...
Andrew Starr wrote 05/04/2016 at 09:03 point
Cool! My ferrite cores are ex-Soviet also
