Putting it all together
A project log for Mighty Lighty
If you can change a light bulb.... You can install this security camera
kelleykelley 05/30/2016 at 02:400 Comments
After switching to the alternative lighting with the smart bulb I was able to put it together pretty quickly.
I installed MotioneyeOS and took the stock raspbian off. Out of the box it is very functional for this particular case but for a production model or consumer version the software would have to be even more user friendly for non tech people. Which is the whole point of this project.
Switching to the smart bulb also meant switching to a slightly different light socket adapter with a 2 prong outlet on the side.
This version of the prototype achieved the following things:
