Little problem
A project log for ScottTV- A Simple MediaPlayer For My Autistic Son
Hi, I needed a simple media player that my son can understand. I could not find a commercial solution, so I built one based on a raspberry
alain-mauerAlain Mauer 06/28/2016 at 05:550 Comments
Scott is regulary tapping and knocking against the front plate, so that yesterday the buttons did stop to work. The problem was very easy to locate. The adapter circuit felt of the raspberry. This time I fixed the adapter on the raspberry with a little bit of hot glue and a cable tie.
