Whoops!
A project log for Light Alarm Arduino Shield
Comes with nRF24L01+ for communications and a RTC for timed animations!
ben-limBen Lim 04/02/2018 at 14:010 Comments
Turns out that I wired up my power MOSFETs wrong, so PWM doesn't really fade the LEDs at the moment. I was using an N-Type MOSFET and a P-Type wiring. Silly me.
But not to worry! I switched the wiring around and sent it off to be made again! You can also use a P-type MOSFET as well
