Reading from MCP342x [16bit Sigma Delta] I2C ADC
A project log for Box0
Free and open source tool for exploring science and electronics anytime anywhere
kuldeep-singh-dhakaKuldeep Singh Dhaka 04/17/2016 at 09:200 Comments
Introduction
We are going to connect and read data from MCP342x [16bit Sigma Delta] ADC.
You can see more on the ADC here
Note: MCP3428 (x = 8) was used.
Connection
CH1+ = Signal+
CH1- = Signal-
CH2+, CH2- = Unused (Floating)
VSS = GND
VDD = 3.3V
SDA = I2C0.SDA
SCL = I2C0.SCL
Adr0 = Floating
Adr1 = Floating
CH3+, CH3- = Unused (Floating)
CH4+, CH4- = Unused (Floating)
Verify Connection
$ b0i2c scan
Slave At: 0x68
Note:
0x68 = 1101 000
   1101 = Hardcoded
   000 = Adr0 and Adr1 Floating
Note: b0i2c is provided by box0-utils.
Code
import box0
from box0.driver import Mcp342x
dev = box0.usb.open_supported()
i2c = dev.i2c()
# Adr0 and Adr1 lines are is Floating
drv = Mcp342x(i2c, Mcp342x.FLOAT, Mcp342x.FLOAT)
# read data
print("Readed Value is: %f" % drv.read())
del drv
del i2c
del dev
Output:
Readed Value is: 1.459563
More code?
Mehhhh, That is high level python code only, gimme the actual code.
Here you go! libbox0/driver/mcp342x/mcp342x.c
