Quick update: 10-tube test
A project log for RPN Nixie Calculator
A programmable RPN calculator using way too many Nixie tubes
robertcbaruchrobert.c.baruch 07/23/2016 at 18:440 Comments
I decided to use a Raspberry Pi 3 to run the display, and tested it using a simple program that uses WiringPi.
Since I'm pretty confident that all the hardware works, I'll be focusing on the software now.
