Configuring the TGAM1 Board for 57600 baud (raw data)
A project log for Train Your Brain with NeuroFeedback
Brain hacking!!! Improve your focus and concentration by training your brain using NeuroFeedback.
tom-meehanTom Meehan 10/03/2016 at 04:120 Comments
Need .png of top of board with white background
Configuring the TGAM1 board for raw EEG data (57600 baud) - using the Hardware method
    1. One way involves programming the TGAM1 board over Bluetooth - if you look through the links at the end of this post you'll find ways of doing this. I did not do it this way, instead I chose the second method.
    2. The second way involves removing a single SMD (surface mount) resistor (pull-down resistor) and adding a different resistor going from the same area and then over to positive connection of the power supply on the TGAM1 board (pull-up resistor).
      • To do this you'll only need:
        1. Basic soldering iron
        2. 1 x 10k 1/8th watt resistor
        3. Heat shrink tubing to insulate the resistor
