Layouting goes on
A project log for 192:LED
Extreme tiny (0,68'‘ x 0,68’‘ or 17mm x 17mm) smart RGB LED display/matrix
alexAlex 04/28/2016 at 20:240 Comments
The layout of the PCB is now nearly ready. I did clean up some of the traces and also did moved some vias out of pads. Now there is now via left inside a pad. The vias itself are also smaller now. Here are two pictures if the top and bottom layer:
The two inner layers are not shown, but there are mostly just two planes for Vcc and GND and not many traces.
I am planning to use OSH Park's 4 Layer service for a first prototype. But first there are some thinks to do:
