Hot Plate Control Algorithm
A project log for Coffee Maker Delta 3D Printer
Built on a coffee maker. And on a budget. No precision rails or bearings. True Delta Kinematics. Great prints.
jcchurchjcchurch 05/30/2016 at 08:020 Comments
The coffee maker hotplate has a significant delay which causes control problems....
By the time the sensor sees a temperature change, enough energy has been put into the plate that it shoots up to a very high temperature. The process does not seem to stabilize with just PID control.
To correct this, we edited the PID algorithm. Now the hotplate is pulsed on between 0 and 1 seconds every 10 seconds according to the PID algorithm.
More details coming....
