All necessary wires attached!
A project log for Megsy? A homebrew Teensy 3++
Creating a double-sized Teensy 3 to allow easy access to the pins that aren't reachable on a breadboard.
t-b-trzepaczT. B. Trzepacz 04/29/2016 at 10:010 Comments
I finally took some time and attached the rest of the necessary wires. I skipped PROGRAM, GOD ,3.3V, and VBat on the end since most of those are available elsewhere several times, or I don't bed then for projects and I can write them up later if I do.
There is a problem that 30 and 31 arm to have become bridged between the boards, but there isn't much I can do about those now. Taking it apart would likely destroy the teensy at this point. It is still 13 I/O pins I couldn't otherwise use!
I'll run some tests and then try soldering on the audio board. .
