Plab spectrometer v2.5 (build 3.0.1)
A project log for DAV 4 UV/VIS Spectrometer
Well, this is the next evolutionary step from when I first bought the Plab 2.5 spectrometer kit
david-h-haffner-srDavid H Haffner Sr 05/01/2016 at 08:031 Comment
I updated the DVD grating this weekend and realigned it, so it is as straight as possible in relation to the slit and remains at a 45 degree angle. With the way it was, I was getting some mis-alignment from time to time, so I had to take care of that.
David H Haffner Sr wrote 05/01/2016 at 08:07 point
I used some very carefully cut yoga blocks, each block is made out of a very high density non compressible black foam material, which I found to have some remarkable light absorbing properties.
This makes for great stability and cost effectiveness.
