Oscilloscope data on the JDEPC-ov04 camera
A project log for DAV 4 UV/VIS Spectrometer
Well, this is the next evolutionary step from when I first bought the Plab 2.5 spectrometer kit
david-h-haffner-srDavid H Haffner Sr 05/05/2016 at 21:410 Comments
I finally got to take some good readings from my oscilloscope program on the JDEPC-ov04 camera in my spectrometer, it doesn't work when the camera is running, but I can get good data on dB levels when it is at rest and on stand-by for data capture.
I did a low pass and a high pass scan:
This is the low pass scan in dB levels at rest.
This is the high pass scan in dB levels at stand-by for data capture.
This is very useful information because now I have a better idea about the spectrometer's internal noise as it relates to data aquisition.
