generate electricity without any input.
Have u think ever!!??? That how it would be if electricity can be generated itself without any input.
I have an idea.
Hello,
I feel excited, and extremely blessed, to be the one used as God’s pen, to tell the world of this mechanism. This miracle is a way of letting electricity generate itself, using time and the circumference difference of two pulleys, so that no fuel is needed, only time is used to multiply electric power. This means that no steady cost of fuel is needed, nor is there any pollution created by the process. That’s right, I will tell you how anyone can get electricity to generate itself.
We could all have our own stand alone, self powering electric generators, that could be producing a seemingly endless supply of free electricity. It is easy enough to build, as all you need is a twelve volt battery, two 12 Volt motors, one large pulley, at least one small pulley, a belt that fits the pulleys, and the hardware to put these parts together.(nuts + bolts + framing to mount on)
((along with electronics, such as wires and a bridge rectifier and a voltage regulator.))
its_not_drew wrote 04/30/2016 at 13:41 point
How is it that all these perpetual motion machines start off requiring a Battery of some sort.
