learning to youtube
A project log for Locomatrix - 3D POV - a different approach
Let's use some rotary to linear movements to display things in 3D. I have no idea if this will work, but hey, I'm gonna try it anyways...
davedarkodavedarko 03/02/2015 at 10:255 Comments
So I fought with blender for the last 3 or 4 days to get this video rendered and cut 50% out. I made a fatal mistake and recorded the whole thing in 50fps and had to find a way to recode it to 25fps - sad that I will have to use Magic Lantern just for the option to record 1280x720 at 25fps, but I will try it. This is unscripted and you can clearly hear me thinking :D There is a jump mark to get to the part where it's moving. Sounds like an old film projector, so I still hope I can get something 3D out of it.
Eric Hertz wrote 03/03/2015 at 08:39 point
nice. Snap-together. Good idea.
Not sure if I said it before, but that rack/pinion system is pretty groovy.
And it looks like it's moving much more smoothly/reliably than before. Awesome.
(Unrelated: I kinda dig the aliasing-effect of it appearing to move much more slowly and somewhat warped in the video. Dang, that thing must be moving *fast!*)
Frank Buss wrote 02/05/2017 at 14:56 point
I downloaded the video, then opened the sound in Audacity, zoomed in where it is moving and selected one second:
Then counting the spikes shows that it is moving with 28 Hz. Probably there is a spike at each end, but then you can update the LEDs in both directions, so 28 fps is possible, if the weight of the LEDs doesn't slow it down too much. Might flicker a bit (flicker free with 50 Hz with a stronger motor), but good enough for a first test.
Stefan-Xp wrote 03/02/2015 at 17:29 point
Nice :) Still curious how it will come out with LED Matrix :)
Best regards / Gruß Stefan
davedarko wrote 03/02/2015 at 18:08 point
thanks :) any animation ideas? I'm thinking of an 8x8x8 princess leia hologram :D well one step at a time..
Stefan-Xp wrote 03/02/2015 at 18:22 point
Perhapps you could reuse some of the 3x3x3 LED Cube ;-)
