Happy Bubbles - NFC Wifi Gadget
Connects to wifi and sends an HTTP request when you touch an NFC tag to it.
This is a device that connects to a wifi network and can read NFC/RFID tags. When you touch one to it, it'll send the tag info to any HTTP URL you'd like.
It's based on the ESP8266 wifi chip and cheap little MFRC522 RFID modules. The firmware was designed to be easy to use and set up.
  • 1 × NodeMCU v2 dev kit
  • 1 × MFRC522 RFID module
  • 1 × (optional) WS2812B LED
