The backbone.
A project log for Modular Unmanned Vehicle Controller
(former YAUVeC - Yet Another Unmanned Vehicle Controller)
e-n-heringE. N. Hering 09/13/2016 at 01:240 Comments
This is the first version of the system backbone. The MCU modules will be plugged to this PCB. The MCU module footprint present on the board is there to receive the communications module, which calls each of the plugged modules, sending or receiving data depending on the module function. In this board is also present a ISP connector to program each module separately and a 12 pin header that will connect the ISP reset to the RESET of the module that will be programmed. Finally, a 4 pin connector is also present, connecting the COM module with the wifi transceiver, via a serial connection. All this information in only one paragraph sounds confusing, I know. If you have questions, please ask. As always, comments are welcome.
