Another addition-based transform
A project log for µδ code
A binary maths hack, for use in DSP code and lossless compression
yann-guidon-ygdesYann Guidon / YGDES 05/24/2017 at 18:120 Comments
Look at these new logs:
https://hackaday.io/project/24834-3rgb-image-lossless-compression-format/log/60063-colorspace
https://hackaday.io/project/7385-recursive-range-reduction-3r-hwsw-codec/log/60068-breakthrough
The have some similarities with µδ but they differ in critical ways:
σα already has a fantastic application in the color decomposition of RGB pictures and will make 3R a truly entropy coder... Follow the developments there !
