3D Leveler
Ths Project is a 3d Level made from 3d abs and a bubble Level
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The 3d leveler assists to level the heads of 3d printers. This particular level helps to level the heads for a Leapfrog Creatr. The addition of the bubble level is to level the print bed and the 3d printer base. The thickness of the card is set for 0.6 mm so that the space of the heads from the print bed can be set to the right height.
