Connections:
netBoot with a case:
Version 1:
Version 2:
Scheme:
Source code:
#include <SPI.h>
#include <UTFT.h>
#include <Ethernet.h>
#include <ICMPPing.h>
byte mac[] = {0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02};
EthernetClient client;
#define MAX_IPs 5
IPAddress pingAddrs[MAX_IPs];
int CNT = 0;
int ERRORS_COUNT = 0;
SOCKET pingSocket = 0;
char buffer [256];
ICMPPing ping(pingSocket, (uint16_t)random(0, 255));
extern uint8_t SmallFont[];
UTFT myGLCD(UNO_26,A2,A1,A3,A4);   //USE  UNO_26 FOR ST7787/7781 / UNO_24 FOR SPFD4508A
int Y = 0;
void setup()
   // Setup the LCD
   pinMode(A0,OUTPUT);    // for the UNO_SHIELD_1IN1
   digitalWrite(A0,HIGH);  // the RD pin must be set high
   myGLCD.InitLCD();
   myGLCD.clrScr();
   pinMode(9,OUTPUT);
   digitalWrite(9,HIGH);
   pinMode(8,OUTPUT);
   digitalWrite(8,LOW);
   Serial.begin(9600);
   Serial.println("Initing...");
   Y = 20;
   myGLCD.setColor(0, 0, 180);
   myGLCD.fillRect(0, 0, 319, 14);
   myGLCD.setBackColor(0, 0, 180);
   myGLCD.setColor(255, 255, 255);
   myGLCD.setFont(SmallFont);
   myGLCD.print("netBOOT - Zola Lab", CENTER, 2);
   myGLCD.setBackColor(0, 0, 0);
   myGLCD.print("Initing...", LEFT, Y);
   Y += 20;
   delay(2000); // mantem 2 segundos com a ethernet desligada (reseta a ethernet)
   digitalWrite(8,HIGH);
   delay(2000); // mantem 2 segundos com a ethernet ligada, antes de executar ethernet.begin
   pingAddrs[0] = IPAddress(74,125,26,147); // google.com
   pingAddrs[1] = IPAddress(8,8,8,8); // dns google
   pingAddrs[2] = IPAddress(200,221,2,45); // uol
   pingAddrs[3] = IPAddress(23,216,170,96); // microsoft
   pingAddrs[4] = IPAddress(31,13,73,1); // facebook
   Y += 20;
   delay(3000);
   while(Ethernet.begin(mac)==0) {Serial.println("Failed to configure Ethernet using DHCP");myGLCD.print("Failed to configure Ethernet using DHCP", LEFT, Y);};
   Clear();
   printIP();
void loop()
  if(ERRORS_COUNT >= 3)
      ERRORS_COUNT = 0;
      boot();
  if(CNT >= MAX_IPs) CNT = 0;
  ICMPEchoReply echoReply = ping(pingAddrs[CNT], 4);
  if(echoReply.status == SUCCESS)
     ERRORS_COUNT = 0;
     sprintf(buffer,
            "IP: %d.%d.%d.%d    TIME: %ldms",
//            echoReply.data.seq,
            echoReply.addr[0],
            echoReply.addr[1],
            echoReply.addr[2],
            echoReply.addr[3],
//            REQ_DATASIZE,
            millis() - echoReply.data.time
//            echoReply.ttl
  else
    sprintf(buffer, "Echo request failed; %d", echoReply.status);
    ERRORS_COUNT ++;
  Serial.println(buffer);
  myGLCD.print(buffer, LEFT, Y);
  Y += 20;
  if(Y >= 240)  Clear();
  delay(1000);
  CNT ++;
void boot()
   Clear();
   Serial.println("BOOT");
   myGLCD.print("BOOT", LEFT, Y);
   Y+=20;
   digitalWrite(9,LOW);  // desliga o modem, por tanto, o relay deve ser usado em NO, ao inves de NC...  ou seja, o relay desligado permite que o router fique ligado. Ao acionar o relay, a energia do router eh cortada.
   delay(5000);  // aguarda 5 segundos com o modem desligado
   for(int j=0;j<150;j++) {myGLCD.print(".", j*2, Y);delay(2500);};
//   delay(60*1000*5); // aguarda 5 minutos para o modem inicializar e reconectar, evitando que a rotina o desligue novamente.
   Y+=20;
   Y+=20;
   printIP();
void Clear()
     Y = 20;
     myGLCD.setColor(0, 0, 0);
     myGLCD.fillRect(0, 20, 319, 240);
void printIP()
   Serial.print("My IP address: ");
   myGLCD.print("My IP address: ", LEFT, Y);
   String IP = "";
   for (byte thisByte = 0; thisByte < 4; thisByte++)
      int ip;
      ip = Ethernet.localIP()[thisByte];
      IP = IP + String(ip) + ".";
   IP = IP.substring(0,IP.length()-1);
   IP = IP + "   ";
   Serial.println(IP);
   myGLCD.print(IP, RIGHT, Y);
   Y+=20;
