Status 6/13/16
A project log for Web Enabled Microscope
Enhance a microscope with web control, enabling gigapixel panoramic or focus stacked shots, live streaming/control and more!
justin-kennyJustin Kenny 06/13/2016 at 19:270 Comments
Received the X and Y axis stepper stages today, have begun modeling the microscope in a basic way to figure out where to mount the focus motor and X/Y motors.
I should be able to wire up the 3 stepper motors to an Arduino with Grbl in the next day or so to get the steps per mm and thus positioning resolution, and will start working the slide holder mechanism.
I've completed modeling an adapter between the stepper motor and Lego wheel, I will 3D print this part to check fitment to the stepper motor and set/mounting screws. Lego parts should arrive later this week.
Specs for the Y-axis motor are as follows:
Motor diameter: 10mm
Motor length: 10mm
Length of rod: 36mm
Slide stroke: 33mm
Winding resistance: 54 ±1 Ω
Step angle: 18°
Drive voltage/current: DC 4-6V / 100-300mA
Specs for the X-axis motor are as follows:
Driving voltage: DC 4-5V
Screw length: 73mm
Slide stroke: 63mm
Screw pitch: 3mm
Step Angle: 18°
Stage size: 90 * 30mm
Specs for the Z-axis motor are found here: http://robocraft.ru/files/datasheet/28BYJ-48.pdf
