first "big" test
A project log for 3D Printed PCB mill
3D Printed components and other hardware to make a PCB routing machine, which inherently can do other things.
dteelDTeel 09/23/2018 at 10:270 Comments
So I was fiddling around and figured making one of those breadboard deals would be a good test so I mocked one up in my CAD program and gave it a go. Turned out pretty good, I dont want to turn on the air compressor and wake my room mate up, so its still got the obvious pcb dust in the nooks and crannies, but electrically it would be fine for a small circuit. The only thing I dont really like about it is the screw hole cutouts, for some reason the Y carriage has some left and right play that only really showed up on the screw holes so I'll need to look at that.
Heres a timelapse that for some reason youtube wont let go above 240p and some after  pictures.
