Testing with aluminum
A project log for 3D Printed PCB mill
3D Printed components and other hardware to make a PCB routing machine, which inherently can do other things.
dteelDTeel 06/17/2016 at 01:150 Comments
well, the drill i was using sucked, the spindle would move around very easy when trying to mill something, so i installed my dremel i have and my aluminum test etching results improved dramaticallly. Still working on the software
