Library Footprint Changes
A project log for DPS-1520AB Server Supply Hotswap Breakout
Power Breakout for RC Chargers and ASIC Miners
charles-lakinsCharles Lakins 06/30/2016 at 14:200 Comments
well the first rev3 arrived from oshpark , however the pci-e footprint needs adjustment
and the hotswap connector holes need to be more oblong for the blade pins as there more shaped like sewing needle heads or spears
Awaiting the new correct connector to compare its design to before changing that again
