Bluetooth Central
A project log for Arduino Glasses a HMD for Multimeter
Building an HMD with no special parts, to make work easier and safer
alain-mauerAlain Mauer 07/23/2016 at 09:020 Comments
I've worked a little bit on the software. I configured the Hm11 as central and I let the module search for BT4.0 devices. After a few try's I made it work. I used a simple written Arduino program to send the serial, Bluetooth data to the USB and vice versa. Now I receive the data from my external device.
This program can be found on my Github (serialtest3.ino)
void setup() {
Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
Serial1.begin(9600); // opens serial port 1, sets data rate to 9600 bps
void loop() {
if (Serial1.available())
Serial.write(Serial1.read()); //read data from Bluetooth and send it to USB
if (Serial.available())
Serial1.write(Serial.read()); //read data from USB and send it to Bluetooth
