PARTS FOR THIS PROJECT
The parts needed are available from any supplier, but I prefer Sparkfun and Futurlec electronic supplier. The list is as follow:
- Six (6 units:3 columns,2 rows for 96x64 resolution) RGB LED Panel - 32x32
- One Teensy 3.1/3.2 (the computer)
- One WiFi Module ESP8266
- One Power Supply (30A). You can recycle any PC Power Supply. I used one from an old IBM Netvista Desktop
- Screen Frame made of aluminium profiles. This can be obtained locally easily.
- One PCB/stripboard with LED BOARD design
- LM1117T-3.3 - LM1117T 3.3V 0.8A Low-Dropout Positive Regulator
- HEADS20 - 20 Pin .100" Straight Male Single Headers
- Two 1/4 W 4.7 K resistors
- One 10 uF Capacitor
- One 1000 uF Capacitor
- Soldering Iron and
- Solder Leaded - 100-gram Spool
