Sunlight has healing powers
A project log for Accelerated Healing
Accelerating your body's healing powers doesn't have to be limited to superhero's. It can be done with a simple LED.
james-cannanJames Cannan 06/19/2016 at 14:210 Comments
What is really interesting is that sunlight naturally has the 660nm light in it. Take a look at the distribution of wavelengths in sunlight from the graph below:
Sunlight Spectrum
Image from http://solarjourneyusa.com/sunlight.php
Basically this means just going outside and getting some sun can help heal your wounds quicker.
WARNING: Although going out into the sun for healing purposes is good, sunlight also contains harmful UV rays that can burn and damage your skin. Therefore having a device that outputs just 660nm light could be better for you in certain situations.
