Testing the BMS with a mockup
A project log for A 110 kWh Powerbucket
The lead-acid batteries of my off-grid solar system are dead. I will replace them by a 18650 batteries stack housed in a big wooden box.
michel-kuenemannMichel Kuenemann 08/27/2016 at 14:350 Comments
I have built a mockup to test the algos of the BMS:
This mockup comprises one single PANASONIC 18650PF cell (in light green).
The cell is connected to the Module management board (on the left, secured with blue cable ties).
On the right of the cell 5 dark green power resistors serve to dissipate the energy of the battery .
Below the cell the Main BMS board manages the charge / discharge cycles.
The cell is charged thanks to a basic linear supply (LM317 + dissipator).
