Raspberry Pi Model B
A project log for Raspberry Pi 3 Desktop a 7-yr-old Can Build & Use
Teach programming, electronics, and mechanics with the Kano Computer and Snap Circuits.
steve-schulerSteve Schuler 06/23/2016 at 11:160 Comments
Specifications:
Processor Broadcom BCM2387 chipset. 1.2GHz Quad-Core ARM Cortex-A53 802.11 b/g/n Wireless LAN and Bluetooth 4.1 (Bluetooth Classic and LE)
GPU Dual Core VideoCore IV® Multimedia Co-Processor. Provides Open GL ES 2.0, hardware-accelerated OpenVG, and 1080p30 H.264 high-profile decode. Capable of 1Gpixel/s, 1.5Gtexel/s or 24GFLOPs with texture filtering and DMA infrastructure
Memory 1GB LPDDR2
Operating System Boots from Micro SD card, running a version of the Linux operating system or Windows 10 IoT
Dimensions 85 x 56 x 17mm
Power Micro USB socket 5V1, 2.5A
Connectors:
Ethernet 10/100 BaseT Ethernet socket
Video Output HDMI (rev 1.3 & 1.4 Composite RCA (PAL and NTSC)
Audio Output Audio Output 3.5mm jack, HDMI USB 4 x USB 2.0 Connector
GPIO Connector 40-pin 2.54 mm (100 mil) expansion header: 2x20 strip Providing 27 GPIO pins as well as +3.3 V, +5 V and GND supply lines
Camera Connector 15-pin MIPI Camera Serial Interface (CSI-2)
Display Connector Display Serial Interface (DSI) 15 way flat flex cable connector with two data lanes and a clock lane
Memory Card Slot Push/pull Micro SDIO
Source: https://www.inet.se/files/pdf/1974044_0.pdf
