A project log for Advanced Fire Search and Rescue Drone
A drone that will be able to navigate its way around inside of a building automatically, such as room mapping, but for the entire building.
austin-tomsonAustin Tomson 04/17/2018 at 17:580 Comments
Drone: Our Drone will be based off of DJI’s Zenmuse XT 2 drone. Some of the differences however, will be the fact that the drone will enter the house and won’t be as expensive and heavy.
Camera: We considered the following different cameras for our Drone:
Brand
Price
Dimensions
Weight
Operating Temperature
Power Consumption
DJI Stereo vision guidance
$999
170mmX170mmX16.2mm
118.6G total
-10C to 40C
12W with all sensors activated
ZED Stereo Camera
$449
175mmX30mmX33mm
159G total
0C to 45C
5V
Scanse meet sweep
$349
65mmX61.9
120G
-10C to 60C
5VDC
DJI Zenmuse XT
Quote
103mmX74mmX102mm
270g
-10C to 40C
Not listed
All of these cameras look great, except that they need to be able to handle being in a fire. We will need to either make the cameras more rugged or get a camera that can handle the extreme conditions that it will be in.
Vision: We had two different options for how the camera will generate a 3d map for us. The first option is Stereoscopic vision. Stereoscopic vision is basically human binocular vision. The second method is Lidar. How Lidar works is that is uses light from a pulsed laser that can measure ranges. It does this will thousands of points that form a 3d map.
We ended up going with Lidar since it doesn’t need visual analysis.
What we will be doing next is looking more at Lidar and rugged Cameras.
