publishing problems
A project log for rain water irragation controler
monitor you water levels in your tank and control 4 irragation zones while monitoring the soil moisture for them
robRob 07/24/2016 at 20:390 Comments
having to publish to 2 systems that have different limits meant reworking the publish script a bit but also allowed me to remove a few hundred milliseconds of delay out of the publishing loop so its down to only 3 100ms delays this should help with all of the timing in general I may reworks this to eliminate all of the delays completely really shouldn't be to hard to add a few more stops in the 2 minute loop I am trying keep the overall bandwidth down to a minimum I may have to make a server side client to to keep track of the published info so that the status page and loads stats instantly on load rather than wait for the device to publish them
maybe webhooks or something can solve this time to learn some more
