Controller board in the enclosure base
A project log for Under Cabinet LED Lighting Controller
An ESP8266 is used to control a 12VDC or 24VDC string of white or RGB LED's.
matt-meerianMatt Meerian 08/30/2016 at 01:010 Comments
The controller board seems to fit well in the enclosure base. (The enclosure is from Bud, model CU-18426-W )
Figure 1: The enclosure (with flanges) and the controller PCB
The red and black wire in the above image is the 12VDC in. The yellow and white wire is anode and cathode leads going out to my LED load.
I'm really a big fan of the red push button. I should to to work it into all of my future projects. :)
I need to post a video sometime of the unit operating.
